Inventor Forum
Can't open old version of file from vault.
5 REPLIES 5
shawnyu
3281 Views, 5 Replies
Dear Sirs,
As attached, the open command is greyed out when I want to open an old verson of a file from Vault 2012, somebody can hlep me to solve it?
My system is Window 7 64-bits, Inventor 2012/Vault 2012.
Thank you!
Shawn
5 REPLIES 5
francesco.tonioni
in reply to: shawnyu
Dear Shawn,
you cannot open the previous versions of a model directly from the Vault. You have to Get it locally (Get Check out command) then open it from local copy.
This is to avoid undesired overwrite of local copy with old file versions. With Get command you will have a warning if local copy is newer.
Hope this helps.
Regards
Francesco Tonioni
Support Specialist
Product Support
Autodesk, Inc.
Mike_Maenpaa
You should not Open files with Vault Explorer.
Select Get/Checkout, which should download the file to your local Workspace, then Open it from your local Workspace.
Mike
shawnyu
in reply to: francesco.tonioni
Thank you very much, Francesco!
shawnyu
in reply to: Mike_Maenpaa
Thank you, Mike, I am going to remember the rule./Shawn
joshuawenzel
Why should you not open files directly from Vault?
