Hi Group,
Help...I cannot open my IPN & IDW files for a job although I still see a
little
preview in the exployer window for both.
A zipped set of the files has been posted to CF under same heading
I think the cause of the problem is that I had to change some IPT & IAM file
name using Design Assistant but I also I inadvertantly changed the file
name on the one IPN file (for an exploded view only) manually in the
exployer, then tried to open the IDW file that ref's it. I get the error
message below when trying to open either IPN or IDW file.
The IAM assembly opens fine.
"Invalid reference to segment objects found"
I renamed the IPN file back to what it was before in the exployer & still
get the error.
I also tried to open files while Design Assist was up but canceled the open
after finding out that was a no-no.
Any help would be very appreciated & will greatly reduce the anxiety factor.
Gary
gcross@crossdesign.com
