Inventor General Discussion
Member
ben_walker5
Message 1 of 27 (2,413 Views)
Can't move unconstrained parts within an assembly
2413 Views, 26 Replies
11-08-2012 08:40 AM
Hi, I have been building an assembly and suddenly I am unable to move parts according to their constraints. I can move them as soon as they are placed but as soon as I add one constraint it's as if they are glued in place. For example, when I line up two holes I can no longer rotate one part around the grounded component.
Have a turned off some functionality of the program?
Any help would be much appreciated!
Ben
Distinguished Contributor
KF090
Message 2 of 27 (2,368 Views)
Re: Can't move unconstrained parts within an assembly
11-16-2012 01:50 PM in reply to: ben_walker5
I'm having this same problem, hopefully there is an easy quick fix.
*Pro
sbixler
Message 3 of 27 (2,346 Views)
11-18-2012 01:11 PM in reply to: KF090
There should be quite a few threads in this forum over the last several years that discuss this problem.  Unfortunately there is no quick fix-- it seems that Inventor can get confused in certain assemblies, and there is no solution other than deleting a bunch of constraints and starting over.  But do some searching and see if there's any more guidance from people with the benefit of experience.
*Expert Elite*
blair
Message 4 of 27 (2,341 Views)
11-18-2012 03:28 PM in reply to: ben_walker5
Look for a bad constraint, this seems to freeze parts, also having a second part selected in the browser will do the same thing as well.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
Valued Mentor
stephengibson76
Message 5 of 27 (2,332 Views)
11-19-2012 01:59 AM in reply to: ben_walker5
do as the others have suggested, but just to get you out of trouble if it needs to go out the door...
Although you can not drag the component, you may be able to move it by adding additional constraints, just add them as you would normally would and see if it moves correctly
Stephen Gibson
View stephen gibson's profile on LinkedIn
Employee
t_stramr
Message 6 of 27 (2,293 Views)
11-21-2012 05:05 AM in reply to: ben_walker5
Hi Ben,
Could you attach your assembly? If you have some simple assembly that exhibits the problem I can take a look closer for source of the problem.
Thank you,
Robert
Active Contributor
rjezuit
Message 7 of 27 (2,274 Views)
11-21-2012 11:02 AM in reply to: t_stramr
I have had this issue also, in 2010, 2011, and 2012.  It seems to be related to previously placed parts that are grounded. If I "un ground" parts placed before the one that is messed up it seems to free them up. Then I ground the previously un grounded parts.
Valued Contributor
Barvas11
Message 8 of 27 (1,676 Views)
09-10-2013 02:41 AM in reply to: ben_walker5
I have the same problem. And as rjezuit says, try to ungound your parts. Every assembly should have only one part grounded no more than that. Another thing that could be causing this are adaptive sketches and parts. You should always turn the adaptivity off.
*Expert Elite*
JDMather
Message 9 of 27 (1,664 Views)
09-10-2013 04:07 AM in reply to: Barvas11
Barvas11 wrote:
.... Every assembly should have only one part grounded no more than that.
I often have multiple grounded components (parts or sub-assemblies) within my assemblies.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
Barvas11
Message 10 of 27 (1,659 Views)
09-10-2013 04:54 AM in reply to: JDMather
Well that's what we were told by Autodesk employees. I must say that it makes my life much easier because assemblies with high number of grounded parts don't tent to behave as they should....
Announcements
Need installation help?
