Hi, I have been building an assembly and suddenly I am unable to move parts according to their constraints. I can move them as soon as they are placed but as soon as I add one constraint it's as if they are glued in place. For example, when I line up two holes I can no longer rotate one part around the grounded component.
Have a turned off some functionality of the program?
Any help would be much appreciated!
Ben
Solved by rrkazman. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Sometimes that the "Free Rotate (G)" command is stuck at some point and froze the assembly.. try free rotating another object to set the assembly free .. it happens me a lot
Hello and welcome to the forums family!
Thank you for your response and helpful advice. Please be aware that this thread is 8 years old, and it is likely that many of the participants are no longer active on these forums.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
@jesse.aumond-beaupre wrote:
Still a problem in 2020.
Can you Attach an assembly here that exhibits this behavior?
Hi Jesse,
A few reasons I can think of to explain the behavior. 1) The part may provide the direction to define a component pattern. 2) The part is adaptive. 3) The part has tangent constraint. Please activate Master LOD and use Rebuild All to see if it frees up. Like JD mentioned here, please share the files. Forum experts can help take a look.
Many thanks!
I have exactly the same problem. I have an assembly with 30 adaptive parts (building a rollercoaster with a lot of splines) But nothing moves anymore everything seems glued in place 😞
I usually have this when I have a red cross, meaning something is wrong with some constrains. If I resolve that issue, mostly I can constrain normally again.
Hi Jacob,
Another possibility is lack of a grounded part. Please make sure a logical component (stationary) is grounded.
Many thanks!
Autodesk Inventor 2023 has an issue where full assemblies doesn't allow for parts to move at all. Parts are constrain properly with one being grounded. Small parts is fine and doesn't have the issue but when doing large assemblies (talking about size and number) it doesn't allow for smaller parts to be move freely with constraint. This makes the assembly process impossible for creating constraints on radius faces or trying to adjust it manually to reduce time on assembly. The type of assemblies would usually take 1 hour max and by the looks it, this version of Inventor will force me to make it in 3 hours.
Hi Carlos,
If I understand your issue correctly, it is the notorious lockup assembly behavior due to a bug in 2023. It has been fixed on 2023.0.1. Please install it and report back your findings.
Many thanks!
I have the same problem after install of Inventor 2023. This is really annoying.
Assembly is ok, no bad constrains. I always was able to pull a part away from an assembly clicking on it with my mouse and dragging it away. Must have something to do with recent update do 2023.
Is this behavior observed in all assemblies or just one particular assembly?
Hi Paul,
Have you installed 2023.0.1 or 2023.1? Does it help? If not, I will need to see the files or a video showing the behavior.
Many thanks!
The issue that I found was that a sub assembly had a slight change in orientation 0.02 degrees of error, because it was inserted into a zero clearance constraint the entire 200 element assembly froze. To repair the issue I had to walk all of the assemblies backwards until I found the one issue. Then rebuild the constraints to allow the motion I wanted. I did not have to remove all of the assembly constraints just those associated with the motion. The error that caused the freeze did not show in the main composite assembly, it only showed up when opening and examining the sub assembly.
i grounded the part that the bearing was going into which solved the problem.
