Inventor Forum
Can't get Insert Constraints to remove all degrees of freedom.
11 REPLIES 11
Message 1 of 12
1482 Views, 11 Replies
I usually start out designing and assembling things using Mate constraints.
Later I add fastener holes, as required, remove the Mate/Flush constraints
by replacing them with Insert Constraints. I've been having issues getting
the parts to assemble in this way, due to error messages. If I check the
alignment of holes, using full precision, the parts line up perfectly.
I can't submit any of my designs due to confidentiality concerns, but would
like to know if anyone else is experiencing this. The workaround I'm using
is to use one Insert and either a Flush constraint, or an Angle constraint.
If anyone has found a reason for the software not being able to remove all
DOFs with Inserts, could you please explain what you did? Is there any way
to set the software to allow, perhaps, a certain amount of assembly error so
the parts will assemble with Insert constraints? I looked for this but
couldn't find any indication that this was possible.
Wally
11 REPLIES 11
Message 2 of 12
When I'm constraining holes, I never use the mate constraints... Why create
twice the constraints in a design? My insert constraints always work unless
there is an error in the spacing. If you need to constrain two parts and
there is an error, then use one insert and a single angle. If I had errors,
the I would take the time to find them.
Since you cannot share any parts for an example, it would be impossible for
anyone here to see where you are going wrong.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
"Wally" wrote in message
news:5749180@discussion.autodesk.com...
Wally
Message 3 of 12
JDMather
Can't you reproduce this behavior in a dummy assembly that does not use your proprietary designs?
Message 4 of 12
An insert constraint will always leave the rotation of the bolt of part free. If your'e using the insert constraint to place parts then just use two insert constraints on two of the holes. The combination will remove any remaining DOF.
Regards
Steve
Message 5 of 12
Hi Dennis,
As I explained: "I usually start out designing and assembling things using
Mate constraints. Later I add fastener holes, as required, remove the
Mate/Flush constraints." Unless I misunderstood, you also have to align
your parts in some way before you add the holes. I assume you don't do this
visually, as this could impact the accuracy of how other things align. So
I'm not sure what you mean when you say: "When I'm constraining holes, I
never use the mate constraints... Why create twice the constraints in a
design?" Fasteners are the glue that hold things together. When loads are
calculated, that is what determines how many fasteners, and where they are
placed. Therefore I assume you must have to always include mate or flush
constraints as an interim step. Otherwise it might become a problem with
complex assemblies, because if the fastener constraints ever become removed
for any reason there is the danger that it could impact many other parts
making recreation of relative part positions impossible.
My issue is that when I use the software's Measure tool, after I've aligned
with an insert constraint and an Angle constraint, for example, the second
set of holes lines up perfectly using full precision. Therefore I shouldn't
have to use the Angle constraint. But I have found, on a couple of
occasions, that this is necessary. This is not a big issue, but it is
curious, because the parts fail to mate with 2 Insert constraints when there
is no calculable error between the holes. It also detracts from progress,
since the reasons for the failure have to be tracked down for significance.
The above is the reason I asked if there is any way to adjust the software's
precision for constraining parts to exclude the occasional times when mating
errors occur. Usually I create hole patterns off of the hole pattern of
another using the Geometry Projection tool. Then I remove all Adaptive and
Reference listings from the Browser followed by constraining the holes with
dimensions to lock the holes in position. My reason for doing this is to
keep the files as lean as possible. Maybe this is where the errors creep
in.
Wally
"Dennis Jeffrey" wrote in message
news:5749204@discussion.autodesk.com...
260-399-6615
Message 6 of 12
Mate constraints. Later I add fastener holes, as required, remove the Mate/Flush constraints.
When constraining most parts (excluding fasteners and round parts meant to be inserted), I would use mate and flush constraints. After the holes are added, I would not remove the mate and flush constraints between the parts. I would only use the insert constraint to add the fasteners. This may seem counterintuitive, however, your holes can be moved and are considered (by me) to be more variable than other more important aspects of the geometry.
Message 7 of 12
JDMather
>the second set of holes lines up perfectly using full precision.
>constraining the holes with dimensions to lock the holes in position.
It sounds like you are doing everything right.
Can you zip and post a non-proprietary dataset that exhibits this behavior?
Message 8 of 12
Hi Wally,
Inventor does not currently provide you with a tolerance preference on
assembly constraints that would allow you to: "...ignore anything after 4
decimal places on INSERT constraints..." or "...ignore anything after 6
decimal places on MATE constraints..."
We have been looking at ways to provide more error tolerance in assemblies
but have not yet decided on the best approach to maintain confidence in the
result while allowing practicalities to be taken into consideration.
Gary R. Smith
Autodesk Inventor Team
Portland, OR
2.33GHz 2GB IBM ThinkPad T60p; XP pro SP2
ATI Mobility FireGL V5250 driver: 8.293.1.0
Message 9 of 12
Our designs are also being bolted together, but I use ZERO insert
contraints...
Skeleton Modeling only requires Flush Constraints (Origin to Origin)
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Autodesk Inventor Suite 2008 SP1
Message 10 of 12
"When I'm constraining HOLES......"
Message 11 of 12
Thanks Gary,
Basically, that's the information I needed. When parts don't mate with
constraints it brings into question whether there are some big errors.
However, if it becomes necessary to fix parts to each other with other than
insert constraints, when there is no noticable error, it adds to the design
difficulties. Since I have a number of nested parts in assemblies, it could
be that this introduces tiny errors that result in Insert mate failures.
Wally
"Gary R Smith (Autodesk)" wrote in message
news:5749720@discussion.autodesk.com...
Hi Wally,
Gary R. Smith
Portland, OR
Message 12 of 12
Hi Josh,
That sounds like good advice. My issue has been trying to keep files as
lean as possible due to the large number of parts. In the past I've relied
on MDT to do 3D design, and it proved incapable of handling large
assemblies. Therefore I'm a little leary about adding anything, even to
Inventor, that might back me into a corner where the capabilities of the
system get maxed out.
Wally
wrote in message news:5749607@discussion.autodesk.com...
