Inventor Forum
Can't get flat pattern
10 REPLIES 10
Message 1 of 11
610 Views, 10 Replies
I have a sheet metal part that was sent to me as .step, and I would like to why I am not able to get a flat pattern with it. Thanks.
10 REPLIES 10
Message 2 of 11
Because Inv does not recognize it as sheet metal.
Look in the browser, you see a "Base1" solid. No folded model, so no flat pattern.
Message 3 of 11
it might have been a sheet metal part in SW where it came from, but now
in Inventor it's still just a dumb solid without any *Inventor* features.
You'll probably have to redo this using Inventors sheet metal tools.
Message 4 of 11
I recieved 2 parts made in SW, the first one I got the flat pattern, but not this one.
Message 5 of 11
You might check out JD's AU video on translations.
http://au.autodesk.com/?nd=class&session_id=3056
You might be able to fix it.
Message 6 of 11
johnsonshiue
Hi! The thickness entered is not precise. The actual thickness on the model is 0.79375mm but the thickness setting is set to 0.794 mm. Please edit the Sheet Metal Rules and change the thickness to 0.79375mm and the flat pattern will work correctly.
Thanks!
johnson.shiue@autodesk.com
Software Test Engineer
Message 7 of 11
Thanks! I look pretty stupid for not thinking of that but I had! And for some reason even when selecting all decimals I was only getting .794. Mystery!
Message 8 of 11
JDMather
Shouldn't matter (and in this case doesn't) if it is a base solid.
Message 9 of 11
JDMather
Well that is strange. That is the first thing I tried and I got .794
Then after Johnson posted I tried again and got his results. Time to go home.
Message 10 of 11
johnsonshiue
The default display precision in Measure tool is set to 3 decimal places. That could explain why you are seeing 0.794 as opposed to 0.79375. I set it to All Decimal to see the true value.
Thanks!
Message 11 of 11
Well, now I have my flat pattern so I'm a happy camper. Thanks everyone for the help and have a good weekend.
