Inventor General Discussion
Valued Contributor
QuasiMojo
Message 1 of 5 (805 Views)
Can't get extrude dialog box back on-screen without second monitor attached
805 Views, 4 Replies
11-11-2012 05:41 PM
Normally I use two monitors, but I'm travelling.  Because I last placed the extrude box on my other monitor I can no longer get access to it on the only screen I have left.  Normally, as with any window, you could hit Alt+Space and M but....the blasted mini-toolbar takes focus first!!  It seems that all the other menus don't have this, only extrude.  Is there any way to reset menus when disconnecting?  There really should be. I'd say that the program ought to know that there is only one monitor connected and respond accordingly.
W7-64, all up to date
Inventor Professional 2014
Windows 7, x64
Dual-core i7, 8GB RAM
NVIDIA Quadro FX 880M
HP Elitebook 8540w
Mark_Wigan
Message 2 of 5 (782 Views)
Re: Can't get extrude dialog box back on-screen without second monitor attached
11-12-2012 04:52 AM in reply to: QuasiMojo
The mini toolbar is a pain as far as I am concerned.
There is a registry setting for the position of these things... I will see if I can dig it up For you.
best regards,
- Mark
PDSU 2014 Windows 7, 64bit. (please consider Kudos or Tag as Solved if your issue is sorted)
Product Support
4donwan4
Message 3 of 5 (740 Views)
11-14-2012 08:33 AM in reply to: QuasiMojo
Take a look at this.
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html and / or
http://www.youtube.com/user/JustinHoey#p/u/4/rRP9sWpFYBM and / or
AT You Own Risk
registry is in HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionxx.0\DockingAreas
Don
New Member
Hill685
Message 4 of 5 (357 Views)
11-26-2013 08:38 AM in reply to: 4donwan4
I am having the same problem.  I have repositioned all of my dialog boxes except for the extrude dialog box.  Do you have any suggestions?
Valued Contributor
graeme.robinson
Message 5 of 5 (108 Views)
06-05-2014 01:15 AM in reply to: Hill685
ALT+SPACE+M
then use cursor keys to move box onto screen
