Normally I use two monitors, but I'm travelling. Because I last placed the extrude box on my other monitor I can no longer get access to it on the only screen I have left. Normally, as with any window, you could hit Alt+Space and M but....the blasted mini-toolbar takes focus first!! It seems that all the other menus don't have this, only extrude. Is there any way to reset menus when disconnecting? There really should be. I'd say that the program ought to know that there is only one monitor connected and respond accordingly.
W7-64, all up to date
The mini toolbar is a pain as far as I am concerned.
There is a registry setting for the position of these things... I will see if I can dig it up For you.
Take a look at this.
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html and / or
http://www.youtube.com/user/JustinHoey#p/u/4/rRP9sWpFYBM and / or
AT You Own Risk
registry is in HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionxx.0\DockingAreas
Don
I am having the same problem. I have repositioned all of my dialog boxes except for the extrude dialog box. Do you have any suggestions?
you are a lifesaver! I pinned this for future reference. And yes, I am admitting to having a Pinterest account.
Per QuasiMojo original posting, the solution to the problem is:
Another method is to use the Inventor reset utility: http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
Mark Lancaster
& Autodesk Services MarketPlace Provider
