When I try the generate a report within Cable & Harness the button stays depressed and no window pops up. I have tried to gereate the report on 2 other stations with the same result. Any ideas?
Inventor Professional 2013
Build: 176, Release: 2013 SP1.1 Update 2 - Date: Tue 01/29/2013
Nvida Quadro 4000
This might be an issue with the particular assembly file. I would use the task scheduler in the tool fly out in the programs group. Here even though you are not migrating to a new release I would rerun the files, assembly and all reference part files, through the migration task. Use the options total rebuild and compact model history. After the files it runs for the migration see if you can then run the cable and harness reports.
Don
Does selecting the top level assembly automatically migrate all of the files within it as well? Not really looking forward to migrating each component individually.
I'm running the IAM right now...
