Inventor General Discussion
Valued Mentor
BLHDrafting
Message 1 of 9 (395 Views)
CAN'T FLAT PATTERN THIS PART
395 Views, 8 Replies
11-01-2012 02:35 PM
Looking for some help in getting this derived/thickened part to flat pattern. I suspect the problem is the cut in the plate edge as can be seen in the below image. Can't figure out how to get rid of it. Zipped files (solid and derived sheet metal part) attached with both parts EOP rolled up. Thanks.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
BLHDrafting wrote:
JD, if you have not yet deleted your part could you share it with me?
You are using earlier release - so you wouldn't be able to open my flle.
I can walk you through the process.
First thing I did is create a line in space for the size of the base and then add coincident constraint between midpoint and origin.
Then I created the three 650mm lines.
JDMather
Message 2 of 9 (382 Views)
Re: CAN'T FLAT PATTERN THIS PART
11-01-2012 03:23 PM in reply to: BLHDrafting
Couldn't the part be done with Lofted Flange?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
JDMather
Message 3 of 9 (372 Views)
11-01-2012 03:56 PM in reply to: JDMather
For your sketches this is the same thing you have but only 3 dimensions.    (equal =) constraints used for the three 650mm dimensions.
Of course my intention is to mirror about Workplane2.
No other construction geometry needed.
JDMather
Message 4 of 9 (368 Views)
11-01-2012 04:09 PM in reply to: JDMather
and Flat Pattern
(not sure why you were doing only half side)
Valued Mentor
BLHDrafting
Message 5 of 9 (363 Views)
11-01-2012 04:22 PM in reply to: JDMather
JD, probably. But I like the derive/thicken method because of the ground and root capability of the parts.
Brendan Henderson
Web www.blh.com.au
JDMather
Message 6 of 9 (360 Views)
11-01-2012 04:33 PM in reply to: BLHDrafting
Your dimensions confuse me (why are you going from a smaller gore to a larger gore and back again), but I think you will have no choice other than to use the sheet metal tools for this as the panels are twisted.
Valued Mentor
BLHDrafting
Message 7 of 9 (357 Views)
11-01-2012 04:39 PM in reply to: JDMather
Thanks JD. I'll have a look at your modelling method. As usual you come up with a much easier method.
Doing only half the side due to need to press these parts. So I'll make a left and right part.
The part is for a silo fumigation system. Fan (aeration) system engineer is telling me they need more volume inside the 90 degree bends. I can't argue with him much as he is the expert in this regard. So I'm just trying to facilitate his needs.
Brendan Henderson
Web www.blh.com.au
Valued Mentor
BLHDrafting
Message 8 of 9 (349 Views)
11-01-2012 04:52 PM in reply to: JDMather
Brendan Henderson
Web www.blh.com.au
JDMather
Message 9 of 9 (321 Views)
11-02-2012 05:20 AM in reply to: BLHDrafting
