Can't flat pattern the same file in an other computer.
I've created an excel based parametric system, and the files are in a server.
I've got a problematic sheet file. When the dimensions stay as they was originally, it can flat, but when I cange some other dimensions (in the full assembly with different parts, what effects this part, becouse they use the same parameter), I can flat it with my computer, but the same file with the same version of Inventor (2015) in a different computer can't be flatten.
Both Inventors have the newest updates, and I exported my setting and imported to the other computer just to try it, and it didn't works.
The K-factor is the same: 0,5.
What can be the problem?
Thanks in advance,
Viktor
mdavis22569
What version of Inventor? 2015 '
Are both machines up to date on patches and updates? Newest ... which is?    What build are you on?
I'm asking as I've seen people say they are updated and one of them wasn't
Can you attach the files for others to look at ?
Mike Davis
Yes, I found it, there is the point!
In my computer, it was 2015 - 5.0.142.9, but the other was 2015 - 5.0.142.5.
I needed to close the Application manager and reopen it, and it founded the updates just after that, so now all things works 🙂
Thank you,
Viktor.
