Inventor Forum
Can't Flat Pattern a Elliptic Sheet Metal with a Cut
8 REPLIES 8
Message 1 of 9
volkan
483 Views, 8 Replies
This seems to very simple but I can't flat pattern the attached part. It has an elliptic shape and I cut it with a profile. If I move the cut under EOP, it flat patterns the part without a problem. Anybody have an idea why I can't flat pattern it with the cut.
Cheers,
Volkan
Volkan ARI
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: volkan
What if you Thicken a trimmed surface body?
Back in a minute with an example.
The CADWhisperer YouTube Channel
Message 3 of 9
johnsonshiue
in reply to: volkan
Hi! This is a bug. There is no reason why it should fail here. I am forwarding it to development for further investigation.
Many thanks!
Software Test Engineer
Message 4 of 9
volkan
in reply to: JDMather
Thank you very much for your soluton, it helped a lot. On the other hand here is another workaround form a friend.
Cheers,
Volkan
Volkan ARI
Message 5 of 9
JDMather
in reply to: volkan
@Volkan wrote:
....On the other hand here is another workaround form a friend.
Volkan
Examine the cut edge of the flat pattern of that "solution" in Wireframe visual style.
There are two curves where there should only be one (cut edge not perpendicular to the flat).
Message 6 of 9
volkan
in reply to: volkan
By the way I think its not a bug, its my fault. 🙂 When I cross the orange border, thickness of sheet metal changes therefore it can't flat pattern.
Cheers,
Volkan
Volkan ARI
Message 7 of 9
volkan
I'm sorry I don't get it. Smiley Sad Does it mean its wrong?
Volkan ARI
Message 8 of 9
JDMather
in reply to: volkan
You tell me.
The edge is cut at a slight angle to the flat.  Does your cutting machine cut straight up and down (perpendicular to the flat) or can it be swiveled at an angle?  If you exaggerate the thickness of the material - the angle becomes more obvious.
Message 9 of 9
volkan
I get it. I talked with my customer he said its ok.
Thank you very much for your help.
Volkan ARI
