I have a client that is trying to use the Cable and Harness feature, but receives the following error:
"The Cable & Harness template was not found. The speicified location for the project is:
[C:\Workspace|Design Data\Cable & Harness|en-US]
Please verify that the template file exists.
He has Inventor installed on his D drive, along with most of his other programs. OS, etc are on the C drive.
I have verified that he has harness.iam and a Cable&HarnessDefaultLibrary.iwl in the following location for Inventor 2013
C:\Users\Public\Public Documents\Autodesk\Inventor 2013\Design Data\Cable & Harness\en-US. As a stab in the dark, I had him copy those files over to his workspace, and re-start Inventor, but same result. Latest updates are installed.
Any help is greatly appreciated.
Solved by Margherita. Go to Solution.
Can they post a capture of the Application Options>File:
See Attached
Hi, I found the answer on this page
Mi problem is different, I reviewed Program Files folders for "Cable and Harness" templates, and there are no templates or any folder named like that... What should I do? Can someone provide me the templates? I can configure path
