I'm having an issue with Inventor such that when I create any new table in a .idw file.....I cannot seem to edit the table. I have tried to double click the newly created table, as well, I have tried to righ-click and select edit. Nothing happens except that Inventor stops responding to all of my requests until I hit ESC.
I feel that it's as if the edit-table pop-up box has popped up but is not visible at all.
Please help.
Here are my specs:
Win 7 ultimate 64 bit
AutoDesk Inventor 2010
64-bit edition
Build 272, release 2010 sp3
Solved by Curtis_Waguespack. Go to Solution.
Hi amalik,
It sounds like the edit dialog is coming up off screen. Have a look at this link:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
I tried that and unfortunately it didn't work. What did happen is that I got my mouse to turn into a 4 way arrow (indicating that I could move something) but I didn't see any sort of a dialog box. I'm totally lost.
@Anonymous wrote:I tried that and unfortunately it didn't work. What did happen is that I got my mouse to turn into a 4 way arrow (indicating that I could move something) but I didn't see any sort of a dialog box. I'm totally lost.
Hi amalik,
After you press M on the keyboard (your cursor will turn into the 4 way arrow) then Immediately press an arrow key on the keyboard. That should attach your cursor to the missing dialog box, so that when you move your mouse around you'll see the dialog box come with. Try it with the Open File dialog or some other dialog that is coming up on screen to see how it works.
Setting the screen resolution up really high as Beemum suggested might help as well, or possibly hooking up another monitor will generally help.
I hope this helps.
Curtis
