When ever I try to edit my parts list in an idw (right click, edit parts list & double click the table) the window seems to freeze, but goes back to normal when I hit ESC. Has anyone else had this issue with Inventor 2010?
Clarify,... are you performing both of those actions? Right clicking and THEN double clicking? Because that would do it right there. In my experience you're probably lucky (if that is what you are doing) not to be looking at your desktop.
On a different note... what are you trying to edit? Is it something that could or should be done in the assembly BOM?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi noahsund_04 ,
I suspect your Parts List dialog box is coming up off screen. See this link for details about how to get it back:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
Hi! The behavior does not sound normal. Does it happen to every partslist or it happens only on specific drawing? Do you see this behavior in other workflows too?
Thanks!
