After inserting an ACAD file in my title block, our company logo, I deleted it and used a PNG file instead. However, some random points and connecting lines to these points were left and I am unable to delete them. I have attached a screen shot showing the intities and how I right-clicked on one, and the DELETE option is not available. I believe these are left over from a spline definition, but I can't seem to get rid of them. They only show up during title block edit. Once I save and get out of the edit mode, you can't see them. Anyone run across this problem before, and have a way to get rid of them?
Inventor Professional 2015
64-bit Windows 7
Bob
Would it be possible for you to post the data set? If it contains confidential information, all I need is the drawing with the title block, no views...
Diane Hawes
Autodesk, Inc.
Diane,
I have attached a ZIP file with, hopefully, all the files you need. I've also included the AutoCAD dwg file that I used to copy and paste into the Inventor Title Block. When you edit the Title Block in the idw, you should see a couple of points and lines that connect them, just below the 2.75 dimension. Please let me know if you can find out something.
Bob
Bob,
Thank you for the data set. It was helpful in tracking down the problem. I can see a number of objects that cannot be deleted in the title block definition. But they are only visible when editing the title block definition, they are not visible in the drawing.
I snooped around in the code and can see why the objects cannot be deleted but I do not understand how they got into that state. That will require some additional investigation. So, I created a bug, TFS Bug 34390. The bug number may appear odd to you. We are using a different application to track our bugs. It is important to keep track of the prefix, "TFS", so we know which system to look it up in.
Thanks again for your help!
Diane Hawes
Autodesk, Inc.
@diane.hawes or @Anonymous did you determine how to remove the points? I have a similar problem [Inventor 2014] but I started with "Define New Zone Border..." command. I then deleted some of the text objects but the based point of the text cannot be deleted.
I opened the VBA editor and found this property.
ThisApplication.ActiveDocument.BorderDefinitions("NAME OF BORDER").Sketch.SketchPoints(1).DisabledActionTypes
The property equals "kDeleteAction" on some points and "kNoAction" on points I can delete.
I attempted to write this to fix this but it has no effect.
oDoc = ThisApplication.ActiveDocument strBorderName = InputBox("Type the EXACT Border Name", "Border", "") oBorder = oDoc.BorderDefinitions(strBorderName) For Each i In oBorder.Sketch.SketchPoints If i.DisabledActionTypes = kDeleteAction Then MsgBox("point " & " : DisabledActionTypes = kDeleteAction") i.DisabledActionTypes = kNoAction End IF Next
