Inventor Forum
Can't create a weld bead report
5 REPLIES 5
582 Views, 5 Replies
Hello guys,
Can anyone help me with this issue? I have an assembly already created with weld bead on it, at the moment I click on creating a weld bead report, it asks me to include all assemblies, I selected the option, and next it opens a window to save the spreadsheet, select the destiny, and next it says that no weld beads were found! report will not be generated. Does anyone have a thought on this?? Thanks in advance!!
5 REPLIES 5
blair
No problems here, either from within the main IAM enviroment or from within the Weld Enviroment. Check that you are current on all SP's and Hot-Fixes.
Inventor version and O/S would help.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
I am using Autodesk Inventor 2012 and Windows 7 ...
I am opening a CATIA file, and the welds are visible, everything seems to be ok, I already updated the SP, but still no weld beam report can be created... Any ideas anyone?
Curtis_Waguespack
Hi diegomb86,
Just to clarify, the weld beads are created in Inventor correct? It sounded a bit like the model and weld beads were created in CATIA and then imported and then you're trying to extract the weld bead report, which won't work.
I hope this helps.
Curtis
Oh ok! Weld beads were created in Catia, so that is the problem, thanks anyway!
