I am having a hell of a time creating drawing dimensions to tangents on a
curve:
I have made a model of a key shape, exactly like on a typical computer
keyboard. Notice that the bottom of a key is flat, but the top of a key is
filleted all around, with the 4 corners being the highest point on the key,
and the center of the key being the lowest point on the top surface.
In a side-view drawing of the part I want to create a dimension from the
bottom of the key to the highest point on the key. This would be the top
quadrant of the fillet. However, it appears to be impossible to select this
tangency point. I am only able to select the endpoints of the fillet curve,
where it is tangent to the side or top surfaces of the key.
Has anyone else seen this behavior? Is there an known issue with creating
tangent dimensions to fillet features???
I *have* been able to dimension from the bottom of the key to the lowest
point on the top of the key surface. I select the bottom straight edge
first, then move the mouse to the bottom of the curve until a small yellow
circle appears, and near that circle appears a "tangency" symbol. This
valley surface is created by a sweep feature. *However*, I have found that
very often when I change the parameters of the model, this dimension in the
drawing file gets updated to a new point, usually to the end of an adjacent
curve or line. It "looses" the point tangent to the curve that I originally
dimensioned to. Very annoying.
- Joe
