Darvin,
Yep I'd already turned them all off a while back. I've just noticed though
that if I resize the whole IV window so that it takes up about 2/3 to 3/4
the screen area the effect goes away and it's instant again. I'm running at
1600 x 1200 x 32bit with the standard blue background.
Cheers
Rob Singlehurst
"darvinv" wrote in message
news:E23B51E44416699817E2DD722D696CFA@in.WebX.maYIadrTaRb...
> rob,
> Do you have any effects turned on in Desktop>Properties? Take a look
> at that and see if there's any good to be done there.
> darvin
> "Rob Singlehurst" wrote in
> message news:208B245159A0860531029503B42D2F19@in.WebX.maYIadrTaRb...
> > Thanks for the prompt reply Darvin,
> > That's what I was afraid of !!
> > Cheers
> > Rob Singlehurst
> > news:0CC53CFA5EAAB39861794B000812F55B@in.WebX.maYIadrTaRb...
> > > Zero difference here.
> > > P4-w2ksp3-750xgl-4103driver
> > > darvin
> in
> > > message news:6B26F75E4797777E6ACA6A6CB64C4710@in.WebX.maYIadrTaRb...
> > > > I'm using a Quadro4 750 XGL with an Athlon XP 2400 (2 GHz) that
> > > appears to
> > > > be working OK with the 44.03 drivers in Full Optimisation mode
> (just
> > > checked
> > > > from the Diagnostics button). If I just start with a new template
> ie
> > > a
> > > > graphics windows open and I click the Start > Run (on the windows
> > > toolbar
> > > > button) there will be a 0.5 to 1 second delay before the Run
> dialog
> > > box
> > > > appears. If I then close the graphic window but still keep
> Inventor
> > > open
> > > > the Run dialog pops up instantly. I would like to know if this is
> > > normal
> > > > for this card (when I try this at home with a 550 there is no
> > > difference
> > > > with the graphics window open or closed).
> > > > Cheers
> > > > Rob Singlehurst
