Inventor Forum
Can someone draw this in inventor 2012 for me?
24 REPLIES 24
Message 1 of 25
1827 Views, 24 Replies
I need help drawing an object in inventor could someone draw it and upload?
24 REPLIES 24
Message 2 of 25
a bit more info please...
what do you want drawn?
heres an object...its a flange Man Surprised
Message 3 of 25
I need the object in the picture done. #6 it includes the measurements but I don't know how to do it
Message 4 of 25
karthur1
Probably 95% of the people here could do this in about 1 minute.. but it wouldnt do you much good.
What you need to do is start a new part, sketch what you see in the top view and extrude it.
Watch this video and it will show you how.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0000-Essentia0/0004-Part_Cre4#GUID-262ECCCB-E5C9...
Post back if you have more questions.
Message 5 of 25
in reply to: karthur1
do what in 1 minute?
was there an attachment that i cant see?
cannoninc   i dont see an image never mind item #6
Message 6 of 25
Martin_Goodland
There is an image of the part drawing in the first post, I am using Crome and can see it.
Regards
Martin
Inventor 2023
Message 7 of 25
Message 8 of 25
You'd be better off doing your own assignments and actually learning how to use the software. But looks like you got some stool to already do your work for you.
Message 9 of 25
JDMather
You might start here.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Hopefully your instructor knows how to use iProperties and gives Karel the credit rather than you.
Message 10 of 25
cbenner
Really?  Coule this part be any easier?  If this is classwork, you should be able to do this on the first day of any Inventor class.  And if it IS classwork, no fair trying to get someone to do your homework for you.
Go ahead and ask questions about specific commands, techniques, etc.  But don't ask us to do your homework for you.
Message 11 of 25
sam_m
in reply to: cbenner
I was tempted to do post it in mm, not converted to mm but at 2.25mm tall...  But hey, got my own work to do
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Message 12 of 25
ampster401
drawn in Inventor 2011, but you can use it in 2012.
No part file needed, just sketched a drawing for you.
HTH
Message 13 of 25
in reply to: sam_m
Good one amp. 🙂
Message 14 of 25
ampster401
OP did say need help drawing...
LOL
Message 15 of 25
cwhetten
I don't see any image attachments either.  I'm using Firefox, just updated to version 11 yesterday.
Anyone else using Firefox 11 who can't see the OP's image?
Message 16 of 25
mrattray
in reply to: cwhetten
I was on Firefox 11 and could see it. I went to check my version to make sure and it updated itself to 12. Still see it.
Mike (not Matt) Rattray
Message 17 of 25
CelticDesignServices
Here you go....took me all of 10 minutes and I had a few emails to answer during that time.
 What do you need help with? It's a pretty simply part. I'm not going to give you the actual file of course, that you'll have to do on your own, but I get the feeling that's what you are trying to avoid....for whatever reason.
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Message 18 of 25
cwhetten
in reply to: mrattray
@mrattray wrote:
...I went to check my version to make sure and it updated itself to 12. Still see it.
Ha ha!  Mine did the same thing! Smiley LOL
Still don't see it, though... Smiley Sad
I posted about this issue on the Discussion Groups Feedback board here:
http://forums.autodesk.com/t5/Autodesk-Discussion-Groups/Attached-images-not-showing/m-p/3428479/mes...
Message 19 of 25
mrattray
My guess would be that you're missing an extension. Here's a cap of my extensions (and an excuse to test another image for you).
Message 20 of 25
Im using chrome...i see your add-ins image but still dont see the op's image
I call our IT the 'Special Host Info Tech Dept...S.H.I.T. for short
We use HP to host our IT services (major Intnl company) they send us z800 workstations (about 12k worth of pc - quadro5000 cards xeon chips etc) but image the machines with XP so half the opengl instruction set doesnt work properly, dont even mention directx.
they block all streamed vid (cant even use the https trick)
has anyone got anyidea what addins or patches i would need?
