wait, you set the color in the part file and then insert and it doesn't
carry thru? That's a new one. It's worked since R1 and ..hold on let me
check...yep still works in R6...
You sure you aren't setting the color in the assy. (in which case it will
not be retained in any other assy or sub)
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"W Massey" wrote in message
news:29413F711ED2985FCAFDDB014EAA4C08@in.WebX.maYIadrTaRb...
> When I insert a part into an assy the color I had set in the part file
> doesn't carry over into the assy. Is there any way to do this with out
> modifying or creating custom materials?
> Thanks,
> Wayne
