Inventor Forum
Can not create a sphere primitive
10 REPLIES 10
Message 1 of 11
jimmylimm
2715 Views, 10 Replies
Hi there,
I have attempted to create a sphere primitive in Inventor 2014 and I get a series of warnings and failure to build the primitive error:
Create revolve feature failed
 -Part2: Errors occurred during update
   -Revolution1: Could not build this Revolution
      -Axis of revolution crosses profile
And I have not been able to find a solution to this. During the sphere creation steps, the sphere appears as a flat circle and not a sphere - Is there a way to fix or debug the sphere creation script?
10 REPLIES 10
Message 2 of 11
blair
in reply to: jimmylimm
It should be this easy:
https://chronicle.autodesk.com/main/details/95e9b9a5-54be-437b-a080-86cfe76183ef
Check that you have all the SP's and Updates installed for your version of Inventor. Links are at the bottom of this web page
Delta Tau Chi ΔΤΧ
Message 3 of 11
JoAnn_Hogan
Did you use the Sphere command or did you do this manually?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 4 of 11
jimmylimm
in reply to: JoAnn_Hogan
I clicked on the "Sphere" primitive icon.
It asks to select a centre point and radius. The result is what you can see in the attached images.
Message 5 of 11
blair
If you are on Win8 / Win 8.1 you need to have all the SP and Updates for SP installed.
Delta Tau Chi ΔΤΧ
Message 6 of 11
JDMather
1. Did you install Service Pack 1 and Update 2 for SP1 as suggested in 1st response?
2. Did you restart Inventor and the problem persists.
3. Did you reboot the computer and restart Inventor and the problem persists in a new file?
4. Is there other geometry in the file where you experienced this problem?  If yes, can you attach the *.ipt file here?
Message 7 of 11
JoAnn_Hogan
in reply to: JDMather
I would suggest that you do a repair through the control panel. If all else fails, try an uninstall and re-install
Jo - Ann
Message 8 of 11
iMaJiNe_Designs
in reply to: blair
The link is broken unfortunately.
Message 9 of 11
This is an old thread, but try this:
- Open a sketch (new or existing)
- In Ribbon click black triangle at Constrain -> Constraint Options
- If no hooks appear at Horizontal and other types, click Select All -> Ok
- New attemt after that
Walter
Walter Holzwarth
Message 10 of 11
Thanks!
Message 11 of 11
guelao78
in reply to: WHolzwarth
Thank you!!!
