I have some Inventor drawing files that a client wants in an AutoCAD 2007 format. Ever time I try to convert the .idw to an autocad .dwg I get this message, "Problems encountered while saving the document." So far this is what I've tried:
1. Save copy as -> Save as type: AutoCAD DWG files (*.dwg) -> error message
2. Export to DWG -> Save as type: AutoCAD DWG files (*.dwg) -> error message
I am able to save as an Inventor DWG but I need it as an AutoCAD DWG... I think. I read somewhere that Autocad 2007 won't read the DWG unless its in an AutoCAD DWG format.
I am running Inventor 2014 on a Windows 7 64 bit machine.
Thanks Mike
Solved by blair. Go to Solution.
The "FIX" does not seem work on my 2015 install either.
Regards.
Blair, MY BAD.
Your fix worked.
I created an error typing in the code.
Thank you for the help.
I shall now attempt to re-grow the hair I pulled out today...............
Try logging in to your machine with a different User Account. You might have a bad profile or create a new folder on your C:\ drive and use that folder to save "Export" or "Save Copy As".
If it works under a differnt User Profile, let me know and I will send instructions on how to repair the User Account.
