Inventor Forum
Can Inventor force a save of a drawing's parts and assemlby to new folder?
3 REPLIES 3
trus
524 Views, 3 Replies
How may I best reuse a legacy assemlby and it's drawing to create/update to an vairant assembly?
3 REPLIES 3
CelticDesignServices
in reply to: trus
Not quite sure I get what you are trying to do, might be that I haven't had my coffee yet this morning.
But have you attempted to do a "save as" to the new folder location?
Are you wanting changes in the assembly to be reflected in other associated assemblies?
Are you using Vault?
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
trus
in reply to: CelticDesignServices
Not using the Vault.  I have an "top-level" assemlby that has three "sub-asseblies" that are nothing more than a variant of one another.  In other words, same parts in differnt locations and rather than building it three times and detailing the its drawing, I'd like to reuse the 1st build sub-assemlby and save it that has both shared parts and ones that only change in their length.  Under the File Save As there's a "Pack and Go" but I can't get it to go. 😕
blair
in reply to: trus
I might just do a Save-Copy As and then just edit each assembly. Possible a screen capture to understand what you are trying to accomplish might help.
I can make a number of completely different assemblies using the same part arranged different ways in each assembly using 4 simple domino tiles all the same tile
1.) long row, end to end
2.) short row, side to side
3.) flat surface, 2 up and 2 across
4.) hollow box
5.) stacked pile
I would want a new drawing for each one
Delta Tau Chi ΔΤΧ
