that may require Autodesk Flow Design or Simulation CFD
which are separate products and purchases
DarrenP
Attached is the output I am looking for. My question is what programs are required analyze the flow as it contacts the deflector wall?
My Secondary question: After the deflector wall in modeled in Inventor, what program is required to APPLY the thrust load to the wall and analyze the structural integrity of the wall components?
Thanks, Terry
Simulation CFD to model the flow and Simulation Mechanical to read in the pressure results and calculate the structural loading 🙂
I'm pretty sure that is an image from Simulation CFD.
We have a dedicated forum if you do move ahead with a purchase.
Jon
Thank you Jon, I will post over there. I have the trial version installed so I will need to get all my questions answered within the trial timeframe. I want to make sure I can acheive the desired analysis before purchasing the numerous packages.
