Inventor Forum
can INV dimension the slot which was generated embossing on a cylindrical body
18 REPLIES 18
Message 1 of 19
dho
1621 Views, 18 Replies
Inventor 2D drawing gives front, left, ... back views from ipt. will it generate expanded view of a cylindrical body surface to be dimensioned (detailed)?
thanks for help.
18 REPLIES 18
Message 2 of 19
bob_holland
in reply to: dho
David,
I took a look at your part and noticed that you did not dimension your slot.
This Inventor works better when sketches are fully constrained.
You can then export the sketch of your slot and the import it into a sketch in your IDW/DWG.
Is this what you are looking for?
Bob Holland
Autodesk Product Support
Message 3 of 19
dho
in reply to: bob_holland
that would be a way. but i just wonder if INV will do that AUTOMATICALLY
like it puts up all the views.
(i did not dimension it, i was just exploring the capability of the INV.)
thanks.
Message 4 of 19
dho
second thought. the export - import will lost the LINK.
agree?
Message 5 of 19
johnsonshiue
in reply to: dho
Hi! Have you tried "Retrieve Dimensions" in the view? Depending on the view direction, right-click on the view -> "Retrieve Dimensions" -> select the part or the features -> select the dimensions to retrieve. The model dimensions will appear in the drawing view. Also you can edit these dimensions to make changes back to the part.
Thanks!
Software Test Engineer
Message 6 of 19
dho
in reply to: johnsonshiue
since the feature is "wrapped" around a cylindrical body, your way seems not working. would you try it, if it works?
thanks.
Message 7 of 19
mrattray
in reply to: dho
I can't look at your part file because I'm still on 2013. Speaking of which, it would be helpful if you would mention your version in the post so we don't have to find out the hard way.
Can you post an image of the part, I have a feeling that you can accomplish what you're after using sheet metal tools.
Mike (not Matt) Rattray
Message 8 of 19
dho
in reply to: mrattray
sorry, INV2014.
here is a screen shot with the sketch shown.
thanks.
Message 9 of 19
WHolzwarth
in reply to: dho
Try this:
- Workplane on cylinder outer dia
- Project emboss sketch
- Create small surface
- Switch only this surface visible in a separate IDW view and place dimensions
Walter
Walter Holzwarth
Message 10 of 19
bob_holland
in reply to: WHolzwarth
Walter,
Thank you.
I have also included a screen cast of pretty much the same steps.
http://screencast.com/t/LHbcDSjLOR8
Please take a look and let me know.
Bob Holland
Message 11 of 19
dho
when set the solid to invisible, the dimensions disappear. right or wrong?
thanks.
Message 12 of 19
WHolzwarth
Hmm, Bob. How could you share the emboss sketch?
I didn't see this option in my files. See attached.
Walter
Walter Holzwarth
Message 13 of 19
bob_holland
Walter,
Sketch 2 appears to have already been shared.
Once it has been shared it shows above the feature that consumed it.
Does this help?
Bob Holland
Message 14 of 19
WHolzwarth
No real help, Bob. I couldn't get this sketch transferred into the IDW.
😉 Well, you have my IPT. Can you add your IDW solution?
Walter
Walter Holzwarth
Message 15 of 19
bob_holland
Walter,
Here you go.
I think that the only part you were missing is Get Model Sketchs.
Bob Holland
Message 16 of 19
WHolzwarth
Thanks, Bob. That did it.
Smiley Embarassed I tried to do that with clicking at the feature (no success), instead at the part icon.
Walter Holzwarth
Message 17 of 19
dho
when retriving the dimensions from 3D model, it works. but with the whole part view with it, a messy thing. if turn off the part visibility, the dimensions go away with it. it can be done to re-dimension the sketch, but it is no longer associated with the model. right?
Message 18 of 19
bob_holland
in reply to: dho
David,
If you dimension the sketch in your IDW/DWG rather than retrieve the dimensions, your IDW/DWG dimensions will update when you change the sketch that you retrieved.
This way you can turn off the solid body and only have your sketch and dimensions.
Please try this and let us know.
Bob Holland
Message 19 of 19
dho
