The new menu system that comes up when you right click. I don't like it, how do I turn it off?
Solved by Curtis_Waguespack. Go to Solution.
Hi zma1013,
You can disable the right-click marking menu and just use the classic old style right-click menu:
http://inventortrenches.blogspot.com/2011/04/bring-back-classic-right-click-menu-in.html
You can also customize the marking menu if that helps:
http://inventortopix.blogspot.com/2011/04/tip-5-autodesk-inventor-2012-customize.html
I hope this helps.
Curtis
Hi colbtron,
You can ask the Maya users at this link:
https://area.autodesk.com/forum/autodesk-maya/
I hope this helps.
Curtis
