Inventor Forum
Can I supress sketch in iPart ?
5 REPLIES 5
Andy_Kuang
442 Views, 5 Replies
When I create a configuration in one iPart, I have one Extrusion’s sketch link to another supressed Extrusion and cause problem.
If I can suppress that sketch and I think the problem will be solved.
Andy
5 REPLIES 5
udayag
in reply to: Andy_Kuang
You could (indirectly) suppress a sketch created on the face of an extrusion by supprerssing that extrusion. So, a posible workaround is to define the sketch on a surface extrusion, and then suppress the extrusion when necessary.
Udaya Gunasena
Fusion Development
Andy_Kuang
in reply to: udayag
Hi Udaya Gunasena,
Thanks to have a look at this issue.
When I change my sketch4 on the surface of Extrusion 3 and my problem was solved.
I had been used Solidworks for more than 10 years, Solidworks is different, I’ll try Solidworks at home tonight and may get back to you.
Thanks again.
Andy
IgorMir
Hi Andy,
The sketch is utilizing projected geometry from the previous extrusion, most likely. That's why it's failing. Don't project the extrusion edges. Project sketch geometry instead. That has been discuss on this forum a few days ago.
Igor.
Web: www.meqc.com.au
Andy_Kuang
in reply to: IgorMir
Thanks mate!
Andy
Melbourne, Australia
IgorMir
You are welcome!
