Good day all.
I need a solution for a challenge that I've been having for a while.
If a place a pipe piece with a length fro example 350mm and I place another pipe piece with a length of 400mm. Is there a way to place the same part with the two (or more) values? I did try the iPart route and to create a multi value in my part parameter for the length equation but in both cases you can only select a length and all the parts in the assembly updates to the new length selection.
Thank you
Gerad.
Is there a reason you can't use Frame Generator for this?
More information is needed.
JD can correct me if I'm wrong, but I believe the short answer is no. One part cannot be in an assembly multiple times with different lengths.
From your description, I still cannot understand why you are not using Tube & Pipe for this. We do flanged, lined steel piping all the time with T&P, I just had to create a custom pipe conduit in the Content Center that has flanged ends. With the T&P styles, you can establish rules for min and max length, and increments. The system is highly flexible,... far from perfect, but from what you wrote, I think it would save you a lot of time and work.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
If I understand you correctly, you might want to save it as a custom part when inserting, not a standard content center part. This way you can give it it's own name, change the size and update the name to match without loosing any of your information already set within it. This should not be done on every occurance, but only those that you know will probably end up changing.
You can also use the replace from content center option or change size option by RMB the standard CC part which will not be available on a CC part set to custom. So there are drawbacks. Have you tried the replace or change size options instead of deleting and inserting a new one? They almost always keep the baloons and such attached to the part that previously existed.
@Anonymous wrote:
.... made us change to the more stable route which was the manually populating a sweep. I
I still think Frame Generator might possibly be a solution. You can add your own profiles. Frame Generator is nothing more than a sweep tool with pre-defined profiles and a few editing enhancements.
Might be worth investing in Routed Systems training as well. I don't have a lot of experience in that area of the product, so not sure what might have been causing the problems you experienced or if training would solve those problems.
I think the difference between a Frame Generator solution and Routed Systems is how the sweep paths are set up.
In Routed Systems it should be a bit easier, but care needs to be taken to get a robust solution.
In Frame Generator you would have to create a skeleton file of sweep paths in a more manual way, but not all that different.
Granted, your name will not update itself if you set it to a custom part, but you can easily retype the partname to match on a custom part which cannot be done on a standard part, except as an overwrite on the drawing parts list. If you have a length field in your part try in the name field to put for example "3/8"Ø x <your length field> Flanged Pipe". This will always put the current length in the name, although you might do that manually on your custom parts as am not sure if it would allow a variable for a standard CC part in the name field.
In Routed Systems it should be a bit easier, but care needs to be taken to get a robust solution.In Frame Generator you would have to create a skeleton file of sweep paths in a more manual way, but not all that different.
The main difference for the way I use Routed Systems vs FG (I use both) is that Routed systems will break the piping around a fitting placed inline, creating 2 spools where there was previously one. This may not be what you need to do, I'm not sure.
The routes are basically 3D sketches and can be constrained just like such. But, as JD said, if you go that route... get some basic training. We were trained in Pro Engineer piping, so the swithc back to Inventor wasn't much of a leap.
Chris Benner
