Inventor 2014 ran brilliantly on my HP G6 laptop, but I have bought an HP Envy m5, and would like to move Inventor to it: is this possible? And if so, how, please?
Welcome to the forum.
Short answer is "No"
The reason being is when you install any program is affects the registry and that is specific to the PC it is on.
You are best just installing it fresh on the new PC selecting the same options as you did on the one that is running smoothly.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
and remember NOT to update to Win8.1 as Inventor will not work (atm)
(if the laptop is already 8.1 then best bet is to wipe and install Win7)
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Probably best to ask your question here
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
if you have trouble transferring the license.
Welcome to the community Roger!
Just wanted to add on here additional information about transferring standalone licenses + how to redownload Autodesk software.
