I need to create an exploded view of an assembly to show how it's supposed to be put together. "Hey, why not use the slick presentation feature in Inventor? I've already got the model!" It's not working out to be that slick.
Outlined in red, is the "wrong" trail that Inventor put in by default. I added the hightlighted trail, which is what I want and reflects how things actually go together. How do I get rid of the one I don't want? Hide turns off both of them. Delete deletes the tweak. All I've found was a workaround where I hide the line in the drawing.
I'm hoping it's just a menu pick or option that I've missed and would appreciate if someone could point that out.
Thanks.
I am not sure if this was because of the "Auto-Explode" when initially creating view. Try creating another IPN file with it set to manual and tweak the parts individually. Not sure if this was what you had already done.
Don
I got disgusted with the whole thing and just put offsets in the original assembly. The advantages were:
Granted, if I wanted to use the annimation feature of Presentations, I couldn't, but I don't need that in this instance.
