After creating a hose it adapts its length to the position I put the assembly in. Is there a way to fix the hose length in a run so that it will not shorten or lengthen according to the position of my assembly?
How did you create this hose? (ie..sweeps,etc.. or via the pipe/tube module)
You won't like it but http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0733-Design_O733/0735-AutoLimi73...
I tried it along time ago with cable/harness files and while it worked you aren't alerted of the over/under limit condition unless you are actually editing the harness or tube run.
@Anonymous wrote:It looks like that will only alert me if something changes but will not prevent it from changing.
GB
Correct.. part of why I said you won't like it.. But its really your only option.
