i.e., is it possible to create a custom iproperty which would enable the user to attach a particular attribute to every component within an assembly without manually going through each component.
For example, If I have a pipework sub-assembly within a manifold assembly. I want to create a custom iProperty for 'Component Type' which would be called 'Pipework' for every component called up within that subassembly.
Likewise for a frame could you have the above custom property attached to every component but called up as 'framework' instead etc.
Thanks in advance. Let me know if im not clear enough!!!
Josh
You can do this by creating a custom iProperty in your template file for those parts. If you already have the model created you can open that model/subassy and add a custom iProperty using the BOM editor. This method is also used for adding custom iProperties to help in sorting parts lists, etc.
If you need specific instructions on how to do this please ask.
Hope this helps, Paul
Josh,
Also if you have vault you can use that same template with the iproperty to auto push to these files if this iproperty is
added to the data card.
