I would like to make the horizontal grid lines on the two walls (Extrusion 15 + Rectangular Pattern 7) and (Extrusion 17 + Rectagular Pattern 😎 into solids that I can export as stls. The table top (Extrusion 1) has a checkered grid pattern that I was able to boolean cut into the table top and thicken into a solid (Thicken 1); however the horizontal grid lines on the walls are not connected to each other like a checkered pattern so when I try the thicken trick on them I get what looks like wood side panels on a house instead of the grid lines.
Please advise. Thank you.
Solved by rdyson. Go to Solution.
@rdyson wrote:
I'm not sure what your intent is, but you seem to be doing way too much work.
I'm with rdyson on that one..
I have no idea what you are really modeling in real life (maybe take a picture so we might suggest proper modeling techniques) but IMO.. "thicken/combine",etc.. shouldn't need to come into play for something like that.
Nor would I ever model what should so clearly be an "assembly" as a single part.
I always say something along the lines of .... "Inventor should follow your real world practices/processes"..
A table leg is a single part in the real world that is assembled to a table base (again a single part)..
Follow the real world and Inventor is cabable of just about anything.
Thank you, the sketch shares, etc worked. How could you tell their was interference between extrusions 9 and 10?
Well, I guess I was kind of sketching it out as I went in Part because I am most familiar with that aspect of the software. Are you aware of any good video series?
