I'm trying to figure out what the additional number in the balloon option "circular w/ 2 entities" represents.
Solved by Curtis_Waguespack. Go to Solution.
HI jpblower,
By default this displays the Item number on top, then the QTY, but you can edit the balloon style to change which one displays on top, or to use different iProperties.
I hope this helps.
Curtis
Not an expert by any means but I did do this the other day. Go into the BOM and create a phantom part. Yhen you can edit the balloon to use the phantom part data
