Inventor General Discussion
n.schotten
Message 1 of 8 (543 Views)
Can a part make alterations to an other part when inserting in an assembly?
543 Views, 7 Replies
03-29-2012 02:27 AM
I've been wondering for some time now if Inventor has this ability.
I have a part that has protrutions. When i mate that part up to another part that second part needs to have cutouts/holes to receive those protrutions.
i mainly use it in sheetmetal parts. and use the rectangular protrutions on de contour to mate up with corresponding cutouts in the other sheet. this helps with positioning and also makes for a nice weld spot/area.
But also for making holes to comodate a mold pin used in custom punch dies. I want the intervering part to receive a corresponding (propperly tolleranced) hole automaticaly. Much like a bolted connection does.
same for parts like circlips. i want them to automaticaly generate the seat in the part it's mated to. Rather than using the axle generator.
Ofcourse one can place the parts and do an in assembly interpart projection and go from there, but i want the part to generate the (predifined) modification to the other part. It would save time and also reduces problems as the parts are moved about or even removed.
First line on that site -
"Use the form below to tell us what you think about our products, their features, and any improvements you would like to see."
I think I saw several instances of the word "automatic" in your problem description.
I think it can be done with Copy Object as surfaces and then Sculpt or using Derived Component - but I don't think that would meet your definition of automatic even if it is associative.
Inventor Tooling works very much as you describe so I assume it could be done, but is not presently in the main worklfow of standard Inventor.
You might try the link I posted originally and suggest any improvements you would like to see.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
No, that isn't what exactly what I meant.
It can be done now with Copy Object or Derived Component (and then additional work like Sculpt or Split).
What I said is that current methods aren't what I expect would meet your definition of automatic.
What I said is that Inventor Tooling does do this fairly automatically in the mold environment (including entry of clearance tolerances) - therefore I'm implying that the developers could achieve what you want.
How many seats of Inventor do you have?  If you have a couple of thousand seats you are more likely to get attention on this request.
JDMather
Message 2 of 8 (528 Views)
Re: Can a part make alterations to an other part when inserting in an assembly?
03-29-2012 05:20 AM in reply to: n.schotten
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
n.schotten
Message 3 of 8 (520 Views)
03-29-2012 06:03 AM in reply to: JDMather
How does a link to a support form help?
Or is it a bit short/terse to let me know that Inventor does not have such a feature?
If so.. why not link to a fearture request form?
JDMather
Message 4 of 8 (523 Views)
03-29-2012 06:22 AM in reply to: n.schotten
JDMather
Message 5 of 8 (511 Views)
03-29-2012 06:28 AM in reply to: n.schotten
Here is another link.
http://forums.augi.com/forumdisplay.php?f=1203
n.schotten
Message 6 of 8 (500 Views)
03-29-2012 06:54 AM in reply to: JDMather
Right... This makes more sense :smileyhappy:
So you think it's fair to say that a part having an assosiated hole/ extruded/revolved cut(subtract) is not currently possible? To bad. and i'll put it up as a feature request. And if others do to it will stand a better chance.
JDMather
Message 7 of 8 (502 Views)
03-29-2012 07:02 AM in reply to: n.schotten
n.schotten
Message 8 of 8 (490 Views)
03-29-2012 07:28 AM in reply to: JDMather
Allass.. just the one seat.
Although we have a 'partner' company that also has 1 seat and does some of what we do (they outsource some design and special builds to the company i work for). so they have the same 'problem' as i have. but he just designs the tab and hole at a static location rather than dynamicly linkt between parts. (measure to fit rather than project loop to fit)
