Inventor General Discussion
Distinguished Contributor
kstate92
Message 11 of 16 (232 Views)
Re: Calibration of CAD software
10-23-2012 07:51 AM in reply to: karthur1
Export a model in a neutral format and verify that file in (something else)? But then, how do you verify / calibrate that (something else)? It's turtles all the way down.
Maybe ask Autodesk for some sort of certification, but I bet somewhere in the 1-point EULA text is something along the lines of 'don't bother asking, pal'.
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
Ryan.Martinez
Message 12 of 16 (224 Views)
10-23-2012 08:03 AM in reply to: kstate92
Next they are going to ask you how you calibrated your calculator. This seems totally crazy to me.
PDS 2014
PDS 2015
hfds006
Message 13 of 16 (203 Views)
10-23-2012 08:56 AM in reply to: kstate92
Thankfully we have never had to deal with this "calibration" question.
Thinking about this I've realized we do have something that could be used to verify the accuracy of our software.
We make a variety of parts that are waterjet cut from steel plate. Typical we produce our part and drawing in Inventor and then save a copy of the Inventor drawing as an AutoCad drawing. The AutoCad drawing is imported into our vendors waterjetting software to be used as a template.
The fact that the finished parts can be physically measured and found to be accurate should verify that our software is accurate. Of course I guess you have to take into account the accuracy of the waterjet process, which is pretty hig but like any manufacturing process not 100%.
Finally, I agree with the others that have stated that this is a silly question.
Richard in Houston
mrattray
Message 14 of 16 (192 Views)
10-23-2012 09:29 AM in reply to: hfds006
CAD is all math. 2+2 will equal 4 no matter what means you use to calculate it. You can't measure math, you can't calibrate it, it just is what it is. Are you going to suggest that if you were to calculate 2+2 on a really mega-fancy pi calculating calculator that can go out to 2000 places, that 2+2 might actually come out slightly off from 4?
Mike (not Matt) Rattray
Valued Mentor
mpatchus
Message 15 of 16 (186 Views)
10-23-2012 09:51 AM in reply to: mrattray
2+2 = 4 only for civilian work, when you work for the government, then it equals whatever the committee formed to evaluate it says it equals.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
mrattray
Message 16 of 16 (179 Views)
10-23-2012 10:09 AM in reply to: mpatchus
In that case, 2+2=5! :smileyhappy:
