Couple of years later I am having the same problem. The table for "ISO 1035/3 - 1980 Hot-rolled steel bars - Part 3: flat bars" is wrong.
Section modulus Wx formula is wrong and it can't be edited because Height G_H, Width G_W are of type "String" and it's expecting values of type "Real" units "mm".
The solution I've come up with was to make another column G_W_N (Width new) and G_H_N (Height new) with exact same values as the original G_W and G_H , BUT made the columns of type "Real" unit "mm".
You then change the formula in the Section Modulus Wx pointing at the new columns and change it to units "mm^3".
