Show only
Search instead for
Inventor does have a Weld-Bead report, it creates a XLS file. A quick use of the Auto-Sum function in Excel will give you the total length of your beads.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. Delta Tau Chi ΔΤΧ
