Inventor General Discussion
Valued Contributor
billjenkins
Message 1 of 5 (356 Views)
Calculating the weight of a part?
356 Views, 4 Replies
11-14-2012 12:29 PM
I would like to find the actual weight of a part in pounds.
I have attached one of the parts I would like to know the total pounds or ounces for.  I’m using a specific material that I set in the Physical tab of iProperties.
Version = Inventor Pro 2009
Thank You,
Bill J.
Good afternoon Bill,
Yes it really is that easy!  Ensure your material/ density is correct and the value given in the Mass box is correct!  You may need to hit Update if you have made any changes to the part.
Thanks to all. This is really helpful and so easy. I try to figure stuff out but there have been several times that I would have been stuck without the assistance I’ve received here.
I do have another question regarding setting up the desired accuracy but I’ll ask about that in a new message.
Bill
mcgyvr
Message 2 of 5 (354 Views)
Re: Calculating the weight of a part?
11-14-2012 12:42 PM in reply to: billjenkins
look at the "physical" tab of the iproperties..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
billjenkins
Message 3 of 5 (341 Views)
11-14-2012 01:34 PM in reply to: mcgyvr
I see 4.184 lbmass (Rela listed in the Mass Window under General Properties located in the Physical tab. Does this mean the part has a weight of 4.184 pounds?
I hope it’s this easy.
Bill
Valued Mentor
GSE_Dan_A
Message 4 of 5 (338 Views)
11-14-2012 01:57 PM in reply to: billjenkins
GSE Consultants Inc.
Windsor, ON. Canada
Valued Contributor
billjenkins
Message 5 of 5 (322 Views)
11-14-2012 04:36 PM in reply to: GSE_Dan_A
Bill
