Inventor General Discussion
Valued Contributor
REDHEADEDCHIMP
Message 1 of 11 (530 Views)
Calculate perimeter
530 Views, 10 Replies
10-01-2007 08:59 AM
Is it possible to calculate the perimeter of the inner and outter edge at the same time.
Distinguished Contributor
Josh_Petitt
Message 2 of 11 (530 Views)
Re: Calculate perimeter
10-01-2007 09:16 AM in reply to: REDHEADEDCHIMP
you might want to read the FAQ first
http://discussion.autodesk.com/thread.jspa?threadID=614626
then, if you want your question answered, list what version of Inventor you are using and describe in detail what you are trying to accomplish. A screenshot of the part/assembly/drawing in question also helps.
*Expert Elite*
JDMather
Message 3 of 11 (530 Views)
10-01-2007 09:26 AM in reply to: REDHEADEDCHIMP
http://discussion.autodesk.com/thread.jspa?threadID=532720
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
REDHEADEDCHIMP
Message 4 of 11 (530 Views)
10-01-2007 09:50 AM in reply to: REDHEADEDCHIMP
I was mainly curious if anyone has an add-in to do it for you. It can be a pain if you have alot of holes.
RonnieWilkins
Message 5 of 11 (530 Views)
10-01-2007 09:56 AM in reply to: REDHEADEDCHIMP
As has been stated above.
Please list your version of Inventor. In the thread linked above I answered how to do this in 2008 using the Region Properties dialog.
Ronnie Wilkins, Jr.
AMS CAD + CAFM Solutions
Sr. Solutions Developer
Autodesk Certified Instructor: Inventor
Valued Contributor
REDHEADEDCHIMP
Message 6 of 11 (530 Views)
10-01-2007 10:24 AM in reply to: REDHEADEDCHIMP
I tried the add to accumulate command in the loop command but it will not let me select a hole. The outside works fine but the hole is like it isn't even there.
petercharles
Message 7 of 11 (530 Views)
10-01-2007 12:11 PM in reply to: REDHEADEDCHIMP
Does this help?
http://discussion.autodesk.com/adskcsp/thread.jspa?messageID=5331057
Valued Contributor
REDHEADEDCHIMP
Message 8 of 11 (530 Views)
10-01-2007 01:00 PM in reply to: REDHEADEDCHIMP
Yeah that should help thanks.
*Johnson Shiue \(Autodesk\)
Message 9 of 11 (530 Views)
10-02-2007 01:29 PM in reply to: REDHEADEDCHIMP
Hi! I am not sure if you are aware of Region Properties tool in Sketch. If
the edges of interest are coplanar, you can create a sketch and project all
the edges. Next, use Tools-> Region Properties. Select the loop you are
interested. It will calculate the perimeters for you.
Johnson Shiue
Inventor QA Tech Lead, Autodesk
johnson.shiue@autodesk.com
wrote in message news:5736815@discussion.autodesk.com...
the same time.
Valued Contributor
REDHEADEDCHIMP
Message 10 of 11 (530 Views)
10-02-2007 02:38 PM in reply to: REDHEADEDCHIMP
That worked great thanks alot.
Need installation help?
