Hi! I am not sure if you are aware of Region Properties tool in Sketch. If
the edges of interest are coplanar, you can create a sketch and project all
the edges. Next, use Tools-> Region Properties. Select the loop you are
interested. It will calculate the perimeters for you.
Johnson Shiue
Inventor QA Tech Lead, Autodesk
johnson.shiue@autodesk.com
wrote in message news:5736815@discussion.autodesk.com...
Is it possible to calculate the perimeter of the inner and outter edge at
the same time.
