Inventor Forum
Calculate perimeter
10 REPLIES 10
Message 1 of 11
4585 Views, 10 Replies
Calculate perimeter
Is it possible to calculate the perimeter of the inner and outter edge at the same time.
10 REPLIES 10
Message 2 of 11
you might want to read the FAQ first
http://discussion.autodesk.com/thread.jspa?threadID=614626
then, if you want your question answered, list what version of Inventor you are using and describe in detail what you are trying to accomplish. A screenshot of the part/assembly/drawing in question also helps.
Message 3 of 11
JDMather
http://discussion.autodesk.com/thread.jspa?threadID=532720
Message 4 of 11
I was mainly curious if anyone has an add-in to do it for you. It can be a pain if you have alot of holes.
Message 5 of 11
RonnieWilkins
As has been stated above.
Please list your version of Inventor. In the thread linked above I answered how to do this in 2008 using the Region Properties dialog.
Ronnie Wilkins, Jr.
Message 6 of 11
I tried the add to accumulate command in the loop command but it will not let me select a hole. The outside works fine but the hole is like it isn't even there.
Message 7 of 11
petercharles
Does this help?
http://discussion.autodesk.com/adskcsp/thread.jspa?messageID=5331057
Message 8 of 11
Yeah that should help thanks.
Message 9 of 11
Hi! I am not sure if you are aware of Region Properties tool in Sketch. If
the edges of interest are coplanar, you can create a sketch and project all
the edges. Next, use Tools-> Region Properties. Select the loop you are
interested. It will calculate the perimeters for you.
Johnson Shiue
Inventor QA Tech Lead, Autodesk
johnson.shiue@autodesk.com
wrote in message news:5736815@discussion.autodesk.com...
the same time.
Message 10 of 11
That worked great thanks alot.
Message 11 of 11
petercharles
Is this available from the API so I can get it automatically? (Only just got 2008 on my computer)
