Hey guys, I have these cable segments in my models. The problem I have is that when I render them or zoom out all of the work points and segment points become visible. It's only when zoomed in that they dissappear.
Look at the attached images for an example.
Is there somehting I'm missing?
I would really like my rendered videos to not have bright yellow spots.
Many thanks
-Chris
Solved by cwhetten. Go to Solution.
You can globally control work feature visibility on the View tab. See the image below. For what you need, I would just turn off the visibility of all your work features (shown in red below).
I also notice in your first image that the iMate glyphs are visible. You can toggle the visibility of iMate glyphs on the same toolbar as mentioned above (see the green scribbles on the above image).
