I have created a cable/harness in my assembly. I have to edit the cable to change visability to centerline display in order to turn off visibility in a drawing view. The issue is that on one sheet of my drawing I need to show the cable, but not on the others. As soon as I turn the rendered display on, the cable shows up on all sheets and the visiblity command has no affect. Is there a hotfix for this? I don't remember a problem like this in 2011.
Solved by alessandro.gasso. Go to Solution.
The hot fix http://usa.autodesk.com/getdoc/id=DL17804781 should solve the problem.
Kind regards,
Alessandro
