Inventor Forum
Cable harness in drawing will not hide
2 REPLIES 2
JeffHobbs6330
391 Views, 2 Replies
I have created a cable/harness in my assembly.  I have to edit the cable to change visability to centerline display in order to turn off visibility in a drawing view. The issue is that on one sheet of my drawing I need to show the cable, but not on the others. As soon as I turn the rendered display on, the cable shows up on all sheets and the visiblity command has no affect. Is there a hotfix for this? I don't remember a problem like this in 2011.
2 REPLIES 2
The hot fix http://usa.autodesk.com/getdoc/id=DL17804781  should solve the problem.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
Thanks for the info.
