Inventor General Discussion
0 Kudos
Post 1 of 4
Cable and Harness Length Control
303 Views, 3 Replies
01-17-2013 12:28 AM
Hi!
I'm creating a wire assembly and i already have in me a length for my wire.
How can I apply this in my assembly for Inventor? It seems only the diameter can be specified but not the length.
Please help.
you have to placed your 2 points you used to create your wire at the distance you need... Or if the wire is not a "right" line but a spline (As for many wiring) and it's to hard to adjust the lenght by the routing you could force the length in the BOM of your part.
John.
Active Contributor
1 Kudo
Post 2 of 4
Re: Cable and Harness Length Control
01-17-2013 03:53 AM in reply to: ericjed13
I couldn't understand your question sir!
0 Kudos
Post 3 of 4
01-17-2013 10:44 PM in reply to: sohmoh
I'm talking about the Cable and Harness Environment in Inventor Pro.
i wanna know if Inventor has this function wherein I could enter or adjust the desired length of wire in my Harness Assembly?
Active Contributor
1 Kudo
Post 4 of 4
01-18-2013 12:20 AM in reply to: ericjed13
John.
Autodesk Product Design Suite Ultimate 2013
Win 7 Pro 64 bits SP1
Bi-Xeon E5520 (2x Quad-core @2.27GHz)
Quadro Fx 1800 768Mo GDDR3
6Go Ram DDR3 667MHz ECC
