I am currently using Inventor Pro 2015 (part of the product design suite ultimate), Win7 64.
I am trying to do a cable run for planning purposes of a wiring job we're doing on our facility. But, I cannot access the cable and harness environment because the button is not visible on the environments tab of the ribbon. I also searched and found the command to start the environment and gave it a keyboard shortcut to see if I could start it that way, to no avail. The add-ins manager says the Cable and Harness add-in is loaded, and it is checked to be loaded at startup automatically. What am I doing wrong?
Solved by JDMather. Go to Solution.
Did you install with antivirus and UAC temorarily disabled.
Are you in the Assembly environment?
Any screen captures?
When you open the Tutorial or Samples examples do you get access?
The CADWhisperer YouTube Channel
