Inventor Forum
Button doesn't respond
3 REPLIES 3
cadlad
271 Views, 3 Replies
Something is wrong with one of my users' Inventor 2013. The issue is that he wants to Save Copy As of an Inventor DWG to an AutoCAD DWG. The Option button in that Save Copy As window, that allows you to choose an ini file, does not respond to clicking, slapping, yelling, or pleading. We've never had this issue. We need that Option box to be clickable for making AutoCAD DWG files for client deliverables and also for creating DXF files for the fab shop.
Dell Precision T3610 - Windows 7 SP1, 64x, 16GB RAM, NVIDIA Quadro K4000 (driver 9.18.13.5306), Inventor 2013 SP2 Update 6 - *Autodesk Inventor Professional Certified*, AutoCAD 2014 SP1, Vault Professional 2014 SP1, 3DConnexion SpaceNavigator
Tags (2)
3 REPLIES 3
CCarreiras
in reply to: cadlad
Hi!
Change to a "Administrator Account", open inventor and try to do it one time (Save as DWG ACAD and DXF).
  • If it doesn´t work, go to "TOOLS ->ADDINS and in tab TRANSLATORS check if DXF and DWG are Loaded.
  • If it works, go back to your account, this will work from now.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
cadlad
in reply to: CCarreiras
The translator loading did not fix the issue.
cadlad
in reply to: cadlad
The problem was fixed by installing the most current Service Packs for Inventor and AutoCAD Mechanical.
