How can tell me where to report bugs I find in Inventor. Just installed 2015 and finding some small things that don't work correct.
Toon
Solved by JoyceZhou. Go to Solution.
I'm talking about small things:
In IDW: I don't want to use "edit demension when created" and disable this after putting in my first dimension but every time I start Inventor it is on again. Same when I disable it in App Options.
In AIM: when using contraint, after picking one item and you want to select the second one you could hover the mouse over an area and after a few seconds you would get a choice which item you wantet to pick (1. Face normal, 2. aksis .......)
I wil make a list and post it here.
Toon
In 2014 was it possible to turn off the "edit dimensions when created" and keep it turned off.
I'm not talking about sketch enviroment but while I'm putting dims on my 2D drawing in IDW.
Just tried it in IV14, I can put dimensions on the drawing without the dialogbox. In app options, drawing the option "edit dim when created" is not checked.
IAM: What I expect is the same as before in 2014, you get a small window and you can scroll through the available options. See attachment.
Toon
Thanks for your help. I changed the delay time from standard (2 seconds) to something else and now it is responding, but before it didn't show at all.
I got the edit dim to work (or not to work 😄 ) as well.
Så for now things seem to work correct.
One other thing that I noticed is when you use Stress Analysis for the first time you have to turn on all the panels, only Finish Stress Analysis shows.
Same for the Frame Analysis.
If I find more I will send it directly to you.
Toon
